New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip # 11222:
Question
With the freeware utility CoDOf (see) you can easily copy drawing objects in a given direction.
Multiply the selected objects by specifying two independent parameters - the direction and offset (distance). You can then repeat the offset manually or automatically (number of repetitions), or you can change it on the go.
Download the application CoDOf (copy with directional offset) from Download, load it with APPLOAD and run it by typing the CODOF command.
See CoDOf in a sample video:
ACAD
15.12.2016
5681×
applies to: AutoCAD ·
