New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip # 11226:
Question
With the free add-on script "RenameComp" (see), you can easily rename components, bodies and sketches in your Fusion 360 designs.
Download the tool from Download and copy it to your folder C:\Users\USERNAME\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\Scripts\. Then press Shift+S and run the RenameComp script.
The option Regular expressions allows to perform complex replacements in the names of your browser tree. RegEx replacements are case-insensitive, plain search-replace is case sensitive and replaces only the first occurrence of the old string.
Fusion360
18.12.2016
12653×
applies to: Fusion 360 360 ·
