Over 1.127.000 registered users (EN+CZ).
CAD tip # 9336:
Question
This error message displayed when attempting to create a parallel geometric constraint (align) between a curve and a text (GCPARALLEL) may be caused by two factors.
- The curve is a part of another existing constraint (e.g. tangential) and this contraint was not created properly. Remove the tangent-constraint.
- The aligned text is using TrueType fonts - this can cause constrain problems in some cases. Temporarily change the text to use a SHX font, create the constraint and then change the text back to TrueType.
ACADADTACADMCivilMap
15.7.2013
11756×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD Architecture · AutoCAD Mechanical · Civil 3D · AutoCAD Map 3D ·
