Over 1.127.000 registered users (EN+CZ).
CAD tip # 8162:
Question
The gTRANS command from the CADstudio TRANS AutoCAD add-on utility has 9 predefined language pairs to translate from-to. So it can automatically translate DWG drawing texts from or to: English, German, Czech, Italian, French, Spanish, Portuguese, Slovak and Finnish.
But you can easily add (or change) your own language - any language supported by Google Translate and based on 8-bit coding. As advised in the TRANS readme, use the gTrans_langlist LISP variable to define the language pairs. E.g.:
(setq gTrans_langlist '(("en" . "English")("nl" . "Nederlands")("no" . "Norsk")("sl" . "Slovenski") ))
will limit the language selection to English, Dutch, Norwegian and Slovenian.
Then just pick the texts to translate automatically (and of course then fix the imperfections of the machine translation).
ACAD
24.8.2011
11994×
this tip shared by ARKANCE experts applies to: AutoCAD ·
