CAD tip CAD tip # 8286:
Question
To display and prnt a point (cross) of the center-of-gravity (COG) of a IPT part or IAM assembly in an Inventor drawing view (IDW, DWG), right-click on the given part in the browser tree and check the COG option in the context menu.
You can dimension and constrain to the COG point.
To transfer the COG point from an IAM assembly to the drawing view in older Inventor versions, use the COG utility, which can be downloaded from DL Download. It creates a dynamic workpoint in the COG.
Inventor2012Inventor2011
26.10.2011   25904×
this tip shared by ARKANCE experts applies to: Inventor 2012 · Inventor 2011 ·
Tip 15141:How to create a point at the center of gravity of a sketch curve in Autodesk Fusion.
Tip 14427:Set the number or description of the COGO point according to the nearest text.
Tip 13827:Snap points to the nearest curve/polyline with Snap2Curve.
Tip 13547:Leaders/Arrows in dragged COGO point labels not pointing to point centers.
Tip 12403:Get center point of a group of selected objects.
Back    All CAD Tips
Categ:
