CAD tip CAD tip # 8281:
Question
It is possible to combine multiple fields in AutoCAD texts and block attributes - not only as an arithmetic expression but also as strings.
String concatenation of the results of multiple fields can be done by simple insertion of multiple fields in a row.
E.g. create a new block in BEDIT and add (define) a new attribute to it (ATTDEF). In the Attribute definition dialog, check the Preset option. In the input box Default, use right click and "Insert field" to add the first part of the resulting dynamic text - e.g. the Y-coordinate of the block insertion point. Type another part of the string, e.g. " / ". Right-click again and insert another field - e.g. the X-coordinate of the newly defined block. Etc. Complete the block definition.
An example of such block with concatenated fields in its dynamic attribute is the block "Bobo" (elevation label) in the Block Catalog.
ACADACLT
23.10.2011   27514×
this tip shared by ARKANCE experts applies to: ACAD · ACLT ·
Tip 15138:AutoCAD Field formatting codes - full list.
Tip 14634:Physical units conversion tool in an Inventor palette.
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 14363:Yesterday's, tomorrow's, past or future date in the DWG drawing.
Tip 14215:IF statement in AutoCAD text fields and attributes.
Back    All CAD Tips
Categ:
