  Visitors: 6210
CAD tip CAD tip # 10118:
How to export a DXF file with punch points from an unfold?
A - answer In the unfold properties (model tree > "Edit Flat Pattern Definition"), use the option to display punch features as points, center marks ("Center Mark Only"). The subsequent DXF exports will represent the punch positions as points (POINT entities) only.
In the model (unfold) tree then choose the context menu function "Save Copy As ..." and use the wizard to set the DXF layer and geometry options as needed.
Inventor
2.12.2014    27023×
Prices - CAD eShop:
applies to: Inventor ·
Tip 12416:How to export DXF outline of unfolded sheetmetal in Fusion 360, with no bending lines.
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Tip 11720:How to export unfolded sheetmetal parts in Fusion 360?
Tip 8509:Unfold any 3D mesh into 2D planar form.
