New CADforum look launched.
Over 1.089.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8439:
Question
If you use long layer names in your AutoCAD DWG files and want AutoCAD to display readable, full layer names in a wider layer control list, you can increase the size directly in the ribbon, use a tear-off tab, or place the layer control in your QAT panel.
For the latter case, use the CUI dialog to add the Layer control to the QAT panel (quick access toolbar). In its properties (the right pane) set the "Minimum width" value to e.g. 400 pixels.
Setting width
Exit the CUI dialog with saving changes. The layer control is now displayed on top, is always easily accessible and has an increased witdth.
QAT Layers
We do not recommend to change the with inside the ribbon as its layout will be affected. But you can tear off the Layers tab (Ctrl+drag) and make it floating independently on the ribbon.
ACAD2012ACAD2011ACLT
26.1.2012    24152×
applies to: AutoCAD 2012 · AutoCAD 2011 · AutoCAD LT ·
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 14384:Wrong encoding of XLS/CSV/TXT files exported from CAD.
Tip 12526:BufZone - buffer zones and wipeouts around AutoCAD line objects.
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Tip 11751:toMulti converts polylines to multi-lines driven by a definition table.
Back    All CAD Tips
Categ:
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
