CAD tip CAD tip # 10432:
Question
You can use Inventor, Revit or any other Windows application (Office, Corel...) to directly open files from your cloud repository in Autodesk A360 Drive. You just need the system component "A360 Desktop" (3D spiral in Windows taskbar) installed and logged-in.
Then you can open all types of files from the automatically synchronized local copy of A360 - the folder (replace the italicized parts with your Windows login name and your Autodesk ID):
C:\Users\{WindowsLoginName}\AppData\Local\Autodesk\Autodesk Sync\Cloud\{A360LoginName}
You can add this folder to your favorites or map it to a disk drive letter.
Any edited files saved to this folder will be automatically updated also in the cloud storage space.
InventorRevitACADMaxSimulation
29.7.2015   23377×
this tip shared by ARKANCE experts applies to: Inventor · Revit · ACAD · Max · Simulation ·
Tip 13770:How do I revert to a previous version of the model in Fusion 360?
Tip 12406:How to log out automatically from your Autodesk account after closing an app?
Tip 11450:How to run Fusion 360 in a web browser? (URL)
Tip 10828:How to control download and installation of updates in Autodesk Desktop App?
Tip 10317:How much slower is saving DWGs to A360 cloud?
Back    All CAD Tips
Categ:
