  Visitors: 2272
CAD tip CAD tip # 8977:
How to reserve an Autodesk floating license for a user or group?
A - answer If you need to reserve (block) some licenses from your Autodesk license server FlexLM/FlexNet for a particular user or a user group, use the option "RESERVE".
In the license folder on your license server, create or edit the text file ADSKFLEX.OPT. Using Notepad.exe, add the reservation lines into this file - e.g.:
RESERVE 1 85768INVNTOR_2012_0F USER usr1
GROUP SUPERCAD usr1 usr2 usr3 usr4 usr5 usr6
RESERVE 4 85871ACD_2013_0F GROUP SUPERCAD
In this example, 1 license of Inventor 2012 is reserved for the user "usr1", and 4 licenses of AutoCAD 2013 are reserved for the group "SUPERCAD" consisting of the users "usr1" to "usr6". You need to restart the license service after you edit the OPT file.
NLM Feature codes can be found on the page Products and on support.autodesk.com.
ACADInvRevitCivilMaxDesignSuite
17.12.2012    11485×
applies to: AutoCAD · Inventor · Revit · Civil 3D · 3ds Max · DesignSuite ·
Tip 13844:With which subscriptions do I get Autodesk Drive cloud storage as a bonus?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 10081:How to reserve a floating license to a specific PC?
Tip 5731:Online statistics reports about active network licenses of CAD software.
Tip 5665:Verbose listing of FlexLM errors.
