  Visitors: 5964
CAD tip CAD tip # 8980:
PLAN view without zooming.
A - answer When switching to a plan view with the PLAN command or with ViewCube, AutoCAD performs a zoom to the whole drawing extents. This may be inconvenient on large drawings (e.g. in civil engineering) as you usually need to re-zoom back to the original detailed view.
In these cases you can use the Express Tools command EXPLAN. This command will switch to the plan view and returns to the original zoom - performs a zoom which approximately equals to the original 3D view. Just respond with 2 [Enters] to its prompts.
ACADADTCivilPlant
18.12.2012    13551×
Tip 14088:3 methods of creating true rectangles in AutoCAD.
Tip 14085:JavaScript API support in AutoCAD and AutoCAD LT.
Tip 14056:How to move blocks in the Z axis to the terrain model surface?
Tip 14033:Clipping blocks, images, curves, xrefs - everything, into any shape
Tip 13975:How to distinguish open tabs in Revit by project?
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
