  Visitors: 7890
CAD tip CAD tip # 11365:
How to store Fusion 360 models directly to Fusion Team projects?
A - answer By default, Fusion 360 uses the "hub" of your private cloud storage in A360 (myhub.autodesk360.com) to save and open its model files.
Using the function "Switch hubs" (in the menu under your account name) you can switch it to any team hub you use (accessible to you) - i.e. a commercial web hub with an individual URL - e.g. mycompany.autodesk360.com). All Fusion files will be then automatically stored to a selected folder in this hub. The setting is stored between sessions.
In higher versions of Fusion 360, you can find this switch in the Data panel, under the top left icon:
Here you can also open the web interface to your hub.
Beside a much larger storage space, you will get all functions for project management, user management, access rights and data sharing options.
See the prices for Fusion 360 and Fusion Team on our CAD eShop (EUR prices for Europe only).
See also cadstudio.cz/a360team and cadstudio.cz/fusionteam
Fusion360A360Team
26.3.2017    8780×
Prices - CAD eShop:
applies to: Fusion 360 360 · A360 · BIM360/Fusion Team ·
Tip 14110:Comparison of speed and CPU core usage in CAM operations of commercial and non-commercial versions of Autodesk Fusion.
Tip 13770:How do I revert to a previous version of the model in Fusion 360?
Tip 12406:How to log out automatically from your Autodesk account after closing an app?
Tip 12314:How to display OBJ models including textures in A360?
Tip 11600:How to rename a project in BIM 360 or Fusion Team?
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
