Over 1.122.000 registered users (EN+CZ).
CAD tip # 8618:
Question
Using WebDAV you can attach your cloud storage Autodesk 360 (resp. AutoCAD WS) as a network disk directly accessible as a standard desktop folder from your local environment in Windows 7 or XP.
- Locate the item (or icon) Computer in the Start menu, right-click on it and select "Map network drive" (in Windows XP use "My network locations")
- In the dialog, click on the link "Connect to a Web site..." - a wizard will be launched
- Confirm the first step with Next
- Select "Choose a custom network location" and click Next
- In the field "Internet or network address" enter https://dav.autocadws.com and click Next
- Enter the credentials for your user account on www.autocadws.com (or AutoCAD WS Mobile), check the option to remember the login
- Give a name to this new network location and click Next
- Click Finish to complete the wizard
- A new Explorer window will open showing the contents of your AutoCAD WS online account
ACADWSDWG
4.5.2012
18813×
