New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 7433:
Question
AutoCAD 2011 (and the whole Autodesk 2011 family) introduces a new alignment (orientation) type for texts in complex linetypes.
In the .LIN linetype definitions with texts or symbols, it has been possible to use the "R" code for relative rotation of the text against the orientation of the line segment, or the "A" code for absolute orientation. The usually used values were only 0 and 90°.
AutoCAD 2011 now offers also another alignment code "U". This code ensures an "always readable" text, i.e. the upright orientation in all directions of the line segments.
Compare the display mode of the standard AutoCAD linetype GAS with the code R and with the new code U:
*GAS,Gas ----GAS----GAS----GAS----GAS----GAS----GAS--
A,12.7,-5.08,["GAS",STANDARD,S=2.54,U=0.0,X=-2.54,Y=-1.27],-6.35
Linetype alignment
You can use the utility CADstudio LTfly (see Download) for an automatic definition of a linetype with an embedded text. This tool automatically uses the U-code for AutoCAD 2011.
ACAD2011LT2011ADT2011Civil2011
29.6.2010    34723×
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Tip 10855:Dynamic linetype scaling by mouse dragging.
Tip 10028:My linetype does not reverse. Why?
Tip 9829:DrGrid - parametric grid for AutoCAD drawings.
Tip 9265:RENAME on steroids - complex renaming of AutoCAD objects (blocks, layers...)
Back    All CAD Tips
Categ:
