CAD tip CAD tip # 7321:
Question
A disabled hardware acceleration on your graphics card can cause AutoCAD cursor moving not smoothly (choppy, jerky, jumpy crosshairs) over your drawing. Hardware acceleration may be disabled as a result of using a non-certified graphics card.
Your cursor than acts like it slowly analyses snap points (even if osnap is disabled).
You can make your cursor faster and smooth by suppressing dynamic mode (DYNMODE=0 or F12 and UCSDETECT), or by enabling hardware acceleration (preferred method). You can do so with the 3DCONFIG command, the "Manual tune" button, check the "Enable hardware acceleration" option.
Slow and jerky cursor movement can be caused also by running BitDefender virus scanner.
On an extremely slow or emulated graphics, also disable the tooltips - ROLLOVERTIPS=0 and TOOLTIPS=0. You may also need to switch off SELECTIONPREVIEW.
For AutoCAD and AutoCAD LT you can also try to switch off the Aero environment in Windows (switch to the Basic theme).
ACAD2012ACAD2011ACAD2010ACLTADTCivilACADM
100% Win7CAD
23.4.2010   54322×   FAQ
this tip shared by ARKANCE experts applies to: AutoCAD 2012 · AutoCAD 2011 · AutoCAD 2010 · ACLT · ADT · Civil · ACADM ·
Tip 15127:3 methods for selecting overlapping objects in Fusion Electronics (PCB).
Tip 15125:Why isn't Revit MCP Server showing up in my Claude AI tool?
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14798:What is the symbol "filled semicircle" next to the cursor in AutoCAD?
Tip 14727:Undocumented option to set up crosshair labels in AutoCAD.
Back    All CAD Tips
Categ:
