New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
Place your Ad on CADforum.cz
CAD tip CAD tip # 7947:
Question
Export of 3D models to the 3D PDF (.pdf) format can be performed in the application Inventor Publisher. Besides the plain publishing of static 3D assemblies from Inventor and any other CAD application, it can create also complete service manuals, explosion views and assembly instructions - not only in PDF, but also in DWF, AVI videoanimations, Flash presentations, or in the .ipm format for the mobile applicaton Inventor Publisher Viewer.
3D PDF model
A sample 3D service manual (Parker) published from an Inventor 3D model - Parker-Service-Manual.pdf (3D PDF, 3.4MB) and the same model in DWF - Parker-Service-Manual.dwf (3D DWF, 2.0MB).
Another option for Inventor is to use the add-on PDF exporter Quadrispace Share3D (supports also IPT/IAM), or using the 3D DWF format as an alternative.
InventorPublisher
30.4.2011    34748×
applies to: Inventor · Publisher ·
Tip 9911:How to copy an AutoCAD DWG drawing into MS Word or other Office software?
Tip 9654:CAD formats supported in online viewer under Autodesk 360.
Tip 8852:Publish interactive 3D models on the web with Autodesk 360.
Tip 8532:Import of 3D DWF files back to editable 3D models.
Tip 8108:Where is the Open button in Inventor Mobile Viewer for Android?
Back    All CAD Tips
Categ:
