  Visitors: 6787
CAD tip CAD tip # 12034:
SolSimilar - select geometrically similar 3D solids.
A - answer With the freeware LISP utility SolSimilar you can automatically select all identical (or closely similar) 3D solids or 2D regions from your AutoCAD DWG drawing.
Download the SolSimilar.vlx file from Download, load it with the APPLOAD command and type the SOLSIMILAR command or use 'solsimilar on any AutoCAD "Select objects:" prompt. All matching solids will be selected (grip-selected).
Pick the sample (primary) 3D solid (3DSOLID object) and all its copies with the same geometry will be also selected. The tool checks the following properties: the type of the solid (box, sphere...), width, depth, height, volume, surface and principal moments. Position, rotation or layer is not relevant.
You can preset the _solsimilarfuzz LISP variable to change the fuzzy-factor for comparison of geometric properties. E.g.:
(setq _solsimilarfuzz 0.001)
and the boolean variable _solsimilarignorerot for ignoring any differences in rotation of objects (both 2D and 3D) - this will match even rotated solids:
(setq _solsimilarignorerot T)
for these two settings, you can also use the commands SolSimilarIgnoreRot (toggle) and SolSimilarFuzz.
SolSimilar
See also Sel3Dsol
ACAD
17.10.2018    14857×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 14056:How to move blocks in the Z axis to the terrain model surface?
Tip 14039:How to display the total volume or surface of 3D solids in DWG?
Tip 13822:Fast layer visibility toggle ON/OFF.
Tip 13809:AutoCAD displays continuous lines and texts as dotted.
Tip 13472:How to convert the structure of a volumetric lattice to a real mesh body?
