New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8194:
Question
To unfold any non-unfoldable 3D objects to two-dimensional shapes (sheetmetal, paper, etc.) you can use approximations. E.g. unfolding of spherical surfaces (sphere, dome) can be approximated using petals, or "orange peels":
orange, mercator
Creating of such unfolded shape for spheres of a given radius can be done in the freeware utility CADstudio SphereUnf - see Download
After loading, running the SphereUnf command and specifying the sphere radius you can pick the place for the unfolded shape and the number of peels for surface approximation - the minimum, 2 peels, make two circular shapes; it is recommended to use at least 8 peels.
After you cut out the peels and bond (weld) them together, you will get the approximation of the original 3D sphere.
See also a sample of such unfold - the drawing SphereUnf.dwg
The SphereUnf utility contains also the command ConeUnf for unfolding of 3D cones (incl. truncated cones).
ACAD
6.9.2011    37411×
applies to: AutoCAD ·
Tip 12416:How to export DXF outline of unfolded sheetmetal in Fusion 360, with no bending lines.
Tip 12411:How to wrap text on a cylinder or a general 3D surface in Fusion 360?
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Tip 12365:How to show color print (sketch) also on the sheetmetal flat pattern?
Tip 12237:UnfoldRS - unfold 3D surfaces to 2D in AutoCAD.
Back    All CAD Tips
Categ:
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
