New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 8192:
Question
External files required to display and publish your DWG file - e.g. fonts (SHX/TTF), xrefs or plot style tables (CTB/STB) - are automatically uploaded to the AutoCAD 360 (Mobile; WS) cloud server when using the function Online > Upload > Upload (UPLOAD).
If you have manually uploaded your DWG drawing to your online account, it is possible to add the missing external files individually, by uploading the requested SHX fonts or similar files. Use the same method as for uploading DWG files - upload the SHX file, it will be automatically placed to the subfolder FONTS. See the Upload button on https://client.autocad360.com/#/filemanager.html.
See a sample drawing
ACADWSACAD360
5.9.2011    18158×
Prices - CAD eShop:
applies to: ACADWS · AutoCAD 360 ·
Tip 14007:Workaround for the missing (vlax-create-object) in AutoCAD LT (voice, clipboard, etc.)
Tip 14006:Universal MsgBox in AutoLISP.
Tip 8705:The easiest way to share DWG drawings online.
Tip 8618:Mapping Autodesk Cloud (AutoCAD WS) as a network disk drive.
Tip 8606:Configuring remote printing from AutoCAD WS Mobile.
Back    All CAD Tips
Categ:
