New CADforum look launched.
Over 1.085.000 registered users (EN+CZ). Try the new Engineering calculator, the CAD conversion wizard, the Color converter and USD viewer. Learn about twiGIS.
CAD tip CAD tip # 8570:
Question
AutoCAD 2013 extends the functionality of loading large point cloud datasets. Besides the original formats LAS, XYB, FWS and FLS, the command POINTCLOUDINDEX now supports also files in plain ASCII format (.xyz, .txt, .asc), Leica format (PTG, PTS, PTX) and Topcon format (CLR and CL3).
point cloud
ACAD2013
4.4.2012    20034×
applies to: AutoCAD 2013 ·
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Tip 13021:Rotating model when hovering above a 3D point cloud. How to disable?
Tip 12938:How to convert a point cloud to a textured 3D model?
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
Tip 12296:Loading a point cloud from a series of photos to Revit.
Back    All CAD Tips
Categ:
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
